东山壹号编译烧写boot make出错
按照配置了所有工具链,最后make时候出现了以下错误,检查后没有遗漏任何步骤:
gz@gz-TN15S:~/workspace/PI1/DongshanPiOne-TAKOYAKI/boot$ make infinity2m_spinand_defconfig
arch/../configs/.tmp_defconfig:326:warning: override: reassigning to symbol CMD_FASTBOOT
# configuration written to .config
gz@gz-TN15S:~/workspace/PI1/DongshanPiOne-TAKOYAKI/boot$ make -j8
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/config.h
  UPD     include/config.h
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
  GCC version: 8.2.1
  MVXV
  CHK     include/generated/timestamp_autogenerated.h
chip_id I2M
  UPD     include/generated/timestamp_autogenerated.h
  CHK     include/config/uboot.release
  UPD     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  UPD     include/generated/version_autogenerated.h
  CC      lib/asm-offsets.s
  CC      arch/arm/lib/asm-offsets.s
  GEN     include/generated/asm-offsets.h
  GEN     include/generated/generic-asm-offsets.h
  HOSTCC  tools/envcrc.o
  WRAP    tools/lib/crc32.c
  WRAP    tools/common/env_embedded.c
  WRAP    tools/lib/sha1.c
  HOSTCC  tools/gen_eth_addr
  HOSTCC  tools/mkenvimage.o
  LDS     u-boot.lds
  HOSTCC  tools/os_support.o
  HOSTCC  tools/aisimage.o
  HOSTCC  tools/atmelimage.o
  WRAP    tools/common/bootm.c
  HOSTCC  tools/default_image.o
In file included from include/config.h:4,
                 from arch/arm/cpu/u-boot.lds:10:
include/configs/infinity2m.h:211:113: 警告: 缺少结尾的 ' 字符
 #define CONFIG_ENV_SIZE         0x1000 // Using 4K length for env is enough, this length must be the s00020000
  WRAP    tools/lib/fdtdec_common.c
  WRAP    tools/lib/fdtdec.c
  HOSTCC  tools/fit_common.o
  HOSTCC  tools/fit_image.o
  HOSTCC  tools/gpimage.o
  HOSTCC  tools/gpimage-common.o
In file included from tools/../include/libfdt.h:54,
                 from tools/fdt_host.h:11,
                 from tools/imagetool.h:22,
                 from tools/aisimage.c:8:
/usr/include/libfdt_env.h:27:30: error: conflicting types for ‘fdt64_t’
   27 | typedef uint64_t FDT_BITWISE fdt64_t;
                 from tools/atmelimage.c:8:
                 from tools/fit_common.c:21:
                 from tools/fit_image.c:17:
In file included from <command-line>:
././include/libfdt_env.h:19:16: note: previous declaration of ‘fdt64_t’ was here
   19 | typedef __be64 fdt64_t;
                 from tools/gpimage.c:22:
In file included from ././include/libfdt_env.h:12,
/usr/include/libfdt_env.h:47:24: error: expected ‘)’ before ‘x’
   47 | static inline uint32_t fdt32_to_cpu(fdt32_t x)
././include/compiler.h:66:9: error: expected ‘)’ before ‘&’ token
   66 |  ((((x) & 0xff000000) >> 24) | \
././include/compiler.h:66:23: error: expected ‘)’ before ‘>>’ token
././include/compiler.h:66:30: error: expected ‘)’ before ‘|’ token
/usr/include/libfdt_env.h:51:23: error: expected ‘)’ before ‘x’
   51 | static inline fdt32_t cpu_to_fdt32(uint32_t x)
make[1]: *** [scripts/Makefile.host:108:tools/kwbimage.o] 错误 1
make[1]: *** [scripts/Makefile.host:108:tools/image-host.o] 错误 1
make[1]: *** [scripts/Makefile.host:108:tools/imximage.o] 错误 1
make: *** [Makefile:1136:tools] 错误 2
请先 登录 后评论
1 个回答
百问网_赵老师
擅长:嵌入式开发
你好,东山派操作请参考:http://dongshanpi.com/
请保持和教程一样开发环境和仔细确认操作步骤,这部分经过众多学员验证过的,通常不会有问题。
请先 登录 后评论
