JZ2440 系统启动报错
今天打开板子学习,结果发现系统启动不了,不论是挂载本地文件系统还是挂载NFS文件系统都不行,我将NAND FLASH 格式化后重新烧入kernel和文件系统也不行,我怀疑是不是开发板硬件出问题,来求助下各位老师,希望大家多多指点!感谢!
Starting kernel ...
Uncompressing Linux...................................................................................................................... done, booting the kernel.
Linux version 2.6.22.6 (root@book-virtual-machine) (gcc version 3.4.5) #1 Tue May 15 19:57:22 CST 2018
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
Machine: SMDK2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0,115200
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00500000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60976KB available (3264K code, 458K data, 140K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, DVS off
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
Registering GDB sysrq handler
JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
yaffs May 15 2018 19:56:07 Installing.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Console: switching to colour frame buffer device 60x34
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO map 0x50000000 mem 0xf0400000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO map 0x50004000 mem 0xf0404000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO map 0x50008000 mem 0xf0408000 (irq = 76) is a S3C2440
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
line 400 <DM9KS> I/O: c486a000, VID: 2b000028
line 400 <DM9KS> I/O: c486a010, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a020, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a030, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a040, VID: 2b002928
line 400 <DM9KS> I/O: c486a050, VID: 2928
line 400 <DM9KS> I/O: c486a060, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a070, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a080, VID: 2b000028
line 400 <DM9KS> I/O: c486a090, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a0a0, VID: 202928
line 400 <DM9KS> I/O: c486a0b0, VID: 2a2928
line 400 <DM9KS> I/O: c486a0c0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a0d0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a0e0, VID: 2a2928
line 400 <DM9KS> I/O: c486a0f0, VID: 2a2900
line 400 <DM9KS> I/O: c486a100, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a110, VID: 2928
line 400 <DM9KS> I/O: c486a120, VID: 2b000028
line 400 <DM9KS> I/O: c486a130, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a140, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a150, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a160, VID: 2928
line 400 <DM9KS> I/O: c486a170, VID: 2928
line 400 <DM9KS> I/O: c486a180, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a190, VID: c1e12928
line 400 <DM9KS> I/O: c486a1a0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a1b0, VID: 2a2900
line 400 <DM9KS> I/O: c486a1c0, VID: 2b000028
line 400 <DM9KS> I/O: c486a1d0, VID: 2a2900
line 400 <DM9KS> I/O: c486a1e0, VID: 2a2900
line 400 <DM9KS> I/O: c486a1f0, VID: 2b000028
line 400 <DM9KS> I/O: c486a200, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a210, VID: 2a2928
line 400 <DM9KS> I/O: c486a220, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a230, VID: 2b000028
line 400 <DM9KS> I/O: c486a240, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a250, VID: 2928
line 400 <DM9KS> I/O: c486a260, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a270, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a280, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a290, VID: 2a2900
line 400 <DM9KS> I/O: c486a2a0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a2b0, VID: 2b2a29ff
line 400 <DM9KS> I/O: c486a2c0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a2d0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a2e0, VID: 2928
line 400 <DM9KS> I/O: c486a2f0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a300, VID: 2b002928
line 400 <DM9KS> I/O: c486a310, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a320, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a330, VID: 2b002928
line 400 <DM9KS> I/O: c486a340, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a350, VID: 2928
line 400 <DM9KS> I/O: c486a360, VID: 2928
line 400 <DM9KS> I/O: c486a370, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a380, VID: 2928
line 400 <DM9KS> I/O: c486a390, VID: 2a2928
line 400 <DM9KS> I/O: c486a3a0, VID: 2b002928
line 400 <DM9KS> I/O: c486a3b0, VID: 2a2928
line 400 <DM9KS> I/O: c486a3c0, VID: 2b000028
line 400 <DM9KS> I/O: c486a3d0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a3e0, VID: 2b2a2100
line 400 <DM9KS> I/O: c486a3f0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a400, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a410, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a420, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a430, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a440, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a450, VID: 28
line 400 <DM9KS> I/O: c486a460, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a470, VID: 2b002928
line 400 <DM9KS> I/O: c486a480, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a490, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a4a0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a4b0, VID: 2b002928
line 400 <DM9KS> I/O: c486a4c0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a4d0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a4e0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a4f0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a500, VID: 2b2a2920
line 400 <DM9KS> I/O: c486a510, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a520, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a530, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a540, VID: 28
line 400 <DM9KS> I/O: c486a550, VID: 2b002928
line 400 <DM9KS> I/O: c486a560, VID: 2a2928
line 400 <DM9KS> I/O: c486a570, VID: 2b000028
line 400 <DM9KS> I/O: c486a580, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a590, VID: 2b002928
line 400 <DM9KS> I/O: c486a5a0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a5b0, VID: 2a2900
line 400 <DM9KS> I/O: c486a5c0, VID: 2b002928
line 400 <DM9KS> I/O: c486a5d0, VID: 2928
line 400 <DM9KS> I/O: c486a5e0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a5f0, VID: 2928
line 400 <DM9KS> I/O: c486a600, VID: 2a2928
line 400 <DM9KS> I/O: c486a610, VID: 2b002928
line 400 <DM9KS> I/O: c486a620, VID: 2928
line 400 <DM9KS> I/O: c486a630, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a640, VID: 2928
line 400 <DM9KS> I/O: c486a650, VID: 2b002928
line 400 <DM9KS> I/O: c486a660, VID: 2b002928
line 400 <DM9KS> I/O: c486a670, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a680, VID: 2928
line 400 <DM9KS> I/O: c486a690, VID: 2b000028
line 400 <DM9KS> I/O: c486a6a0, VID: 2b000028
line 400 <DM9KS> I/O: c486a6b0, VID: 2a2900
line 400 <DM9KS> I/O: c486a6c0, VID: 2a2928
line 400 <DM9KS> I/O: c486a6d0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a6e0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a6f0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a700, VID: 2a2900
line 400 <DM9KS> I/O: c486a710, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a720, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a730, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a740, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a750, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a760, VID: 2b000028
line 400 <DM9KS> I/O: c486a770, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a780, VID: 2b2a0020
line 400 <DM9KS> I/O: c486a790, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a7a0, VID: 2928
line 400 <DM9KS> I/O: c486a7b0, VID: 2a2928
line 400 <DM9KS> I/O: c486a7c0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a7d0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a7e0, VID: 2a2928
line 400 <DM9KS> I/O: c486a7f0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a800, VID: ff2a2928
line 400 <DM9KS> I/O: c486a810, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a820, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a830, VID: 2b002928
line 400 <DM9KS> I/O: c486a840, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a850, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a860, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a870, VID: 2b002928
line 400 <DM9KS> I/O: c486a880, VID: 2b000028
line 400 <DM9KS> I/O: c486a890, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a8a0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a8b0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a8c0, VID: 2a2900
line 400 <DM9KS> I/O: c486a8d0, VID: 2b002928
line 400 <DM9KS> I/O: c486a8e0, VID: 2928
line 400 <DM9KS> I/O: c486a8f0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a900, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a910, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a920, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a930, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a940, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a950, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a960, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a970, VID: 2b2a2928
line 400 <DM9KS> I/O: c486a980, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a990, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a9a0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486a9b0, VID: 2b000000
line 400 <DM9KS> I/O: c486a9c0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486a9d0, VID: ff242928
line 400 <DM9KS> I/O: c486a9e0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486a9f0, VID: 2a2928
line 400 <DM9KS> I/O: c486aa00, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aa10, VID: 2b002928
line 400 <DM9KS> I/O: c486aa20, VID: 2b002928
line 400 <DM9KS> I/O: c486aa30, VID: 2b2a0000
line 400 <DM9KS> I/O: c486aa40, VID: 2a2928
line 400 <DM9KS> I/O: c486aa50, VID: 2928
line 400 <DM9KS> I/O: c486aa60, VID: 2928
line 400 <DM9KS> I/O: c486aa70, VID: 2928
line 400 <DM9KS> I/O: c486aa80, VID: 2928
line 400 <DM9KS> I/O: c486aa90, VID: 2a2900
line 400 <DM9KS> I/O: c486aaa0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486aab0, VID: 2a2928
line 400 <DM9KS> I/O: c486aac0, VID: 2b000028
line 400 <DM9KS> I/O: c486aad0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486aae0, VID: 2a2928
line 400 <DM9KS> I/O: c486aaf0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab00, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab10, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab20, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab30, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab40, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ab50, VID: 2928
line 400 <DM9KS> I/O: c486ab60, VID: 2a2928
line 400 <DM9KS> I/O: c486ab70, VID: 2b000028
line 400 <DM9KS> I/O: c486ab80, VID: 2a2928
line 400 <DM9KS> I/O: c486ab90, VID: 2b2a0028
line 400 <DM9KS> I/O: c486aba0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486abb0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486abc0, VID: 2a2900
line 400 <DM9KS> I/O: c486abd0, VID: 2a2928
line 400 <DM9KS> I/O: c486abe0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486abf0, VID: 2a2900
line 400 <DM9KS> I/O: c486ac00, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ac10, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ac20, VID: 2b2a0000
line 400 <DM9KS> I/O: c486ac30, VID: 2a2900
line 400 <DM9KS> I/O: c486ac40, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ac50, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ac60, VID: 2b2a0028
line 400 <DM9KS> I/O: c486ac70, VID: 2a2900
line 400 <DM9KS> I/O: c486ac80, VID: 2928
line 400 <DM9KS> I/O: c486ac90, VID: 2b000028
line 400 <DM9KS> I/O: c486aca0, VID: 2b002928
line 400 <DM9KS> I/O: c486acb0, VID: 2928
line 400 <DM9KS> I/O: c486acc0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486acd0, VID: 2a29ff
line 400 <DM9KS> I/O: c486ace0, VID: 2a2928
line 400 <DM9KS> I/O: c486acf0, VID: 2928
line 400 <DM9KS> I/O: c486ad00, VID: 2b2a0028
line 400 <DM9KS> I/O: c486ad10, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ad20, VID: 2a2900
line 400 <DM9KS> I/O: c486ad30, VID: 2b2a0000
line 400 <DM9KS> I/O: c486ad40, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ad50, VID: 2b2a0000
line 400 <DM9KS> I/O: c486ad60, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ad70, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ad80, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ad90, VID: 2a2928
line 400 <DM9KS> I/O: c486ada0, VID: 2928
line 400 <DM9KS> I/O: c486adb0, VID: 2b2a0028
line 400 <DM9KS> I/O: c486adc0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486add0, VID: 2b002928
line 400 <DM9KS> I/O: c486ade0, VID: 2b2a0000
line 400 <DM9KS> I/O: c486adf0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ae00, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ae10, VID: 2b2a0028
line 400 <DM9KS> I/O: c486ae20, VID: 2a2928
line 400 <DM9KS> I/O: c486ae30, VID: 2b2a2900
line 400 <DM9KS> I/O: c486ae40, VID: 2a2928
line 400 <DM9KS> I/O: c486ae50, VID: 2b000028
line 400 <DM9KS> I/O: c486ae60, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ae70, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ae80, VID: 2b2a2928
line 400 <DM9KS> I/O: c486ae90, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aea0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aeb0, VID: 2b2a2900
line 400 <DM9KS> I/O: c486aec0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aed0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aee0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486aef0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486af00, VID: 2b2a2900
line 400 <DM9KS> I/O: c486af10, VID: 2b2a2928
line 400 <DM9KS> I/O: c486af20, VID: 2b2a29e1
line 400 <DM9KS> I/O: c486af30, VID: 2b002928
line 400 <DM9KS> I/O: c486af40, VID: 2b002928
line 400 <DM9KS> I/O: c486af50, VID: 2b2a2900
line 400 <DM9KS> I/O: c486af60, VID: 2a2900
line 400 <DM9KS> I/O: c486af70, VID: 2b2a0000
line 400 <DM9KS> I/O: c486af80, VID: 2928
line 400 <DM9KS> I/O: c486af90, VID: 2b2a2928
line 400 <DM9KS> I/O: c486afa0, VID: 2b2a2928
line 400 <DM9KS> I/O: c486afb0, VID: 2a2928
line 400 <DM9KS> I/O: c486afc0, VID: 2928
line 400 <DM9KS> I/O: c486afd0, VID: 2a2928
line 400 <DM9KS> I/O: c486afe0, VID: 2b000028
line 400 <DM9KS> I/O: c486aff0, VID: 2b002928
Unable to handle kernel paging request at virtual address c486b000
pgd = c0004000
[c486b000] *pgd=3046b011, *pte=00000000, *ppte=00000000
Internal error: Oops: 807 [#1]
Modules linked in:
CPU: 0    Not tainted  (2.6.22.6 #1)
PC is at dmfe_probe1+0x44/0x3c0
LR is at 0xc0365ed8
pc : [<c001d25c>]    lr : [<c0365ed8>]    psr: a0000013
sp : c046ff24  ip : c0365ed8  fp : c046ff58
r10: 00000000  r9 : 00000000  r8 : c00231a8
r7 : c0390344  r6 : c06e6800  r5 : 00000000  r4 : 2b002928
r3 : 00000028  r2 : c486b000  r1 : 00000001  r0 : c486b000
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  Segment kernel
Control: c000717f  Table: 30004000  DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc046e258)
Stack: (0xc046ff24 to 0xc0470000)
ff20:          00000000 336e6000 00005544 c06e6800 00000000 00000000 c046e000
ff40: c00231a8 c0024864 00000000 c046ff70 c046ff5c c001d5fc c001d228 00000000
ff60: 00000000 c046ff80 c046ff74 c001d6a8 c001d5e8 c046fff4 c046ff84 c0008a94
ff80: c001d650 e59b2004 e1a00005 00000000 00000001 e3500000 00000000 00000000
ffa0: 00000000 c046ffb0 c002bf24 c0041330 00000000 00000000 c00089c0 c00476f0
ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0: 00000000 00000000 00000000 c046fff8 c00476f0 c00089d0 e5993000 e0233002
Backtrace:
[<c001d218>] (dmfe_probe1+0x0/0x3c0) from [<c001d5fc>] (dmfe_probe+0x24/0x68)
[<c001d5d8>] (dmfe_probe+0x0/0x68) from [<c001d6a8>] (dm9dev9000c_init+0x68/0x98)
 r5:00000000 r4:00000000
[<c001d640>] (dm9dev9000c_init+0x0/0x98) from [<c0008a94>] (kernel_init+0xd4/0x28c)
[<c00089c0>] (kernel_init+0x0/0x28c) from [<c00476f0>] (do_exit+0x0/0x760)
Code: e5972000 e3520201 e1a00002 328004f3 (e5c03000)
Kernel panic - not syncing: Attempted to kill init!
请先 登录 后评论
2 个回答
hpshpsh
路過~ LOG看起來的錯誤段是在Kernel位置~
建議用原始的imageimage或重新編譯Kernel試試看
请先 登录 后评论
星星之火 - 嵌入式工程师
擅长:答疑助手
你直接烧录老师编译好的bin试一下
请先 登录 后评论
  • 2 关注
  • 0 收藏,35 浏览
  • 君莫叹流年 提出于 2020-07-28 20:23
相似问题
