1.只修改韦老师board_rk3288.c里的寄存器设置就好
2.下面是board_rk3288.c的全部内容,替换原来的内容就好,其它文件不用改:
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/errno.h>
#include <linux/miscdevice.h>
#include <linux/kernel.h>
#include <linux/major.h>
#include <linux/mutex.h>
#include <linux/proc_fs.h>
#include <linux/seq_file.h>
#include <linux/stat.h>
#include <linux/init.h>
#include <linux/device.h>
#include <linux/tty.h>
#include <linux/kmod.h>
#include <linux/gfp.h>
#include <asm/io.h>
#include "led_yellow_opr.h"
static volatile unsigned int *CRU_CLKGATE14_CON;
static volatile unsigned int *GRF_GPIO8A_IOMUX;
static volatile unsigned int *GPIO8_SWPORTA_DDR;
static volatile unsigned int *GPIO8_SWPORTA_DR;
static int board_demo_led_init (int which) /* 初始化LED, which-哪个LED */
if (which == 0)
if(!CRU_CLKGATE14_CON)
CRU_CLKGATE14_CON = ioremap(0xFF760000 + 0x0198, 4);
GRF_GPIO8A_IOMUX = ioremap(0xFF770000 + 0x0080, 4);
GPIO8_SWPORTA_DDR = ioremap(0xFF7F0000 + 0x0004, 4);
GPIO8_SWPORTA_DR = ioremap(0xFF7F0000 + 0x0000, 4);
printk("%s %s line %d, led %d\n", __FILE__, __FUNCTION__, __LINE__, which);
// rk3288 GPIO8_A2
/* a. 使能 GPIO8
* set CRU to enable GPIO8
* CRU_CLKGATE14_CON 0xFF760000 + 0x198
* (1<<(8+16)) | (0<<8)
*CRU_CLKGATE14_CON = (1<<(8+16)) | (0<<8);
/* b. 设置 GPIO8_A2 用于 GPIO
* set PMU/GRF to configure GPIO8_A1 as GPIO
* GRF_GPIO8A_IOMUX 0xFF770000 + 0x0080
* bit[3:2] = 0b00
* (3<<(2+16)) | (0<<2)
*GRF_GPIO8A_IOMUX = (1<<(4+16)) | (0<<4);
/* c. 设置 GPIO8_A2 作为 output 引脚
* set GPIO_SWPORTA_DDR to configure GPIO8_A1 as output
* GPIO_SWPORTA_DDR 0xFF7F0000 + 0x0004
* bit[1] = 0b1
*GPIO8_SWPORTA_DDR |= (1<<2);
static int board_demo_led_ctl (int which, char status) /* 控制LED, which-哪个LED, status:1-亮,0-灭 */
printk("%s %s line %d, led %d, %s\n", __FILE__, __FUNCTION__, __LINE__, which, status ? "on" : "off");
if(which == 0)
if(status)//on: output 0
/* e. 设置 GPIO8_A2 输出低电平
* set GPIO_SWPORTA_DR to configure GPIO8_A1 output 0
* GPIO_SWPORTA_DR 0xFF7F0000 + 0x0000
* bit[1] = 0b0
*GPIO8_SWPORTA_DR &= ~(1<<2);
else//off: output1
/* d. 设置 GPIO8_A2 输出高电平
* set GPIO_SWPORTA_DR to configure GPIO8_A1 output 1
* bit[1] = 0b1
*GPIO8_SWPORTA_DR |= (1<<2);
static struct led_operations board_demo_led_opr = {
.num = 1,
.init = board_demo_led_init,
.ctl = board_demo_led_ctl,
struct led_operations *get_board_led_opr(void)
return &board_demo_led_opr;
2 篇文章
